Darius »
https://forums.nicoclub.com/darius-u5470.html
Tue May 29, 2007 6:38 am
Your oil pump is a mechanical pump running off of your crank, therefore, pressure will be zero when the engine is not turning. According to the FSM, the oil pressure should be 14 psi at idle, 43 psi at 2000 rpm, and 57 psi at 6000 rpm. Sounds like your sending unit is toast or that you have a blockage downstream of your sending unit. I'd put a mechanical gauge on there to see if your sending unit is bad. If the result is the same, then I'd start to worry about big issues.
