1. Break loose lug nuts2. Jack up & take off wheel3. Take out fender liner, this is held by plastic clips & phillips headed screws4. Reach in twist out bulb socket5. Replace bulb6. Re-install front fender liner7. Put on wheel & tighten lug nuts8. Lower wheel & torque lug nuts to spec.Done!Tommygunn wrote:Been trying to replace highbeam on my 2003 Z and have no luck, how do you take the headlight off to get to the H7 highbeam????
