2003 Maxima SERVICE ENGINE SOON
DS2003MAXIMA
Car: 2003 Nissan Maxima SE
just cleaned my throttle body and 5 days later the service engine soon light is on...only disconnected the MAF sensor and intake plumbing so that i could get to the front of the throttle body...what if any ideas do you have? :gotme
otto888man
Double check the connector going to the MAF sensor if its plugged in properly. I hope this helps.
Keep us posted.
OM
rioredstang
Car: 1993 240sx SCCA ITS
Go and have someone read the codes and post them for us.
I don't how you cleaned it, but the electronic throttle bodies do not like carb cleaner, or spraying them down. If you unplugged the throttle body it has to relearn min. idle. Most likely you will have to find someone with a scanner that can perform this.
