I have a 6 SPD Maxima 2003. Following two issues:
1. I can smell Gas when i turn the car on COLD. At first it was strong, that it appeared to be coming from passenger side in front through the Heating/AC vents...but that disappeared, now it comes from behind the exhaust. Not so much inside the car, but if the door is open you can definately smell it. Again, its only when car is started Cold and not moving. Also, my mileage seems to have dropped alot. NO CHECK ENGINE light !!!! could it be O2 sensors ???
2. I hear some sound/noise randomly over the bumps. how do i tell apart that its bushings, sway bar links, inner tie rods or Indeed Hub Bearings ???
Thanks in Advance.
