2003 Maxima Electrical Problems
wglover
Car: 2003 Maxima GLE
Hello, I survived the recent storm in CT - 38 inches of snow followed by rain. I believe I may have a wet window and door lock control panel issue. I have read that I should try to dry it out first before attempting anything else.
:confused:
Here is the issue. The passenger side window and door lock is not operating from both the master control on the driver side and front passenger door. The pendant control does operate the locks though. I have checked fuses, with no results. So if there are any other suggestions I would welcome your thoughts and advice.
I hope to hear from you all!
Kind regards,
Wayne
maxhopper
Car: 02 Maxima SE 6spd
Welcome to NICO!
Here is a link to the electrical section of the FSM. Power window system starts on page EL-251 http://www.nicoclub.com/FSM/maxima/2003/el.pdf. Page EL-262 has the components to check for your window issue. Door locks are discussed immediately following power windows in the manual.
wglover
Hi Scott, I will check harness where I can access it , pull the control panels on each door and check electrical contacts and clean them, do what I can for what its worth.
Do you know where the circuit breaker is E90 pg 267? I am hoping this is the whole problem.
If note then - without the consult II which I assume only a dealer has which is a computer, I'll then have no recourse but to go there an get charged $400.00 to find the problem, or so it seems. I do appreciate your response.
Best regards,
Wayne
maxhopper
See page EL-466 for location. It appears to be in the passenger side foot well (possible behind the kick panel).
