The car has stalled three times this week. the problem coincides with new full tank of premium gas. After the third stall the check engine light came on. I am now on another new tank of gas, replaced the air filter & added Lucas fuel injector cleaner to my last fill-up.
Three weeks ago I had the oil cooler seal was replaced, oil & filter changed by the dealer. Brake job and left front strut replaced.
Can I expect the check engine light go off similar to when the gas cap is loose & tightened? or Should I suspect a more serious problem?
