2003 Maxima Belt Replacement
mlahc56mlahc
Car: 2003 Nissan Maxima SE
Need to replace the drive belts for 2003 maxima. How big a job is this? Any advice or guidance would be helpful.
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
If its like the 95 Maxima, the power steering belt will be the worst to replace.
yangs13
Car: 1993 240sx-Dead, 2001 Maxima
FSM http://www.nicoclub.com/FSM/maxima/2003/should be in the maintenance section. i think.
NutriaforBreakfast
You want to avoid overtightening so you dont burn up a bearing inyour AC or PS-but you dont want the belt flopping around too looseeither. They say to use a belt deflection gauge but I just cant useone under the hood since it is so crowded. A new belt will stretchafter a little while so you can fine tune how tight it needs to be.You may just have to use good judgement and watch how the carruns for this. I think most mechanics changing belts really do thisanyway. Be sure to clean off any oil or antifreeze from the pulleysbefore installing. Bring the old one with you to check the size whenpurchasing.
