M45Caliber wrote:Also -- I've spoken with 3 service advisors and 2 service managers (Infiniti) and NONE of them have ever heard of "Cooling Fan FLuid"hrase
I just googled that "phrase" and nothing comes up either --
szhosain - can you elaborate on this recommendation or point me in the right direction as to where this item is located, etc.?
It would be fun to "show the dealer something they don't know!"
thanks --
1. Show them page 8-4 of the 2003 M45 Owner's Manual and ask them why item 4 on that diagram points to a "Cooling Fan Fluid Reservoir" if there is no Cooling Fan Fluid!
2. Ask them why they don't check it every time the car is in for service ... show them the instructions on page 8-10 and ask them why they don't check the Cooling Fan Fluid level!
3. Show them the instructions on page 9-4 and ask them why they don't check the Cooling Fan Fluid lines for "proper attachment, leaks, cracks, etc." like it says to do!
4. Show them the Capacity tables on page 10-2 and ask them why it says to use Nissan PSF II for the Cooling Fan Fluid.
By this time, they ought to get it! If not, ask them to look at page CO-18 through CO-20 of the 2003 M45 Service Manual in the Engine Cooling section, which shows how to replace the Cooling Fan Fluid entirely!
Remember to tell them to bleed the air out of the lines properly when they change the fluid, and have them check the fins of the "Cooling Fan Fluid Cooler" while they are at it ... yes, the Cooling Fan Fluid has a Cooler too!
Enjoy having fun with the Service Advisors on this item!!
BTW, I believe in RTFM ... when I first got my car, I read through the Owners Manual front to back and was taken by surprise by this too! When I asked my Service Advisor to change it, he was flabbergasted, but he checked ... and sure enough ... he found it in the Service Manual and I had it done.
FWIW, on my new car purchases, I like to do some crazy things. Somewhere in the first few hundreds to 10k miles, I like to replace all fluids near moving parts in the car. Manufacturing procedures and tolerances being what they are, metal is often "deburred" into the fluids during the early operation of the vehicle. I believe in removing these before they can cause problems elsewhere!
Enjoy!!
Z
