GJEMD wrote:"The lower cover is also part of the engine heat management system with the air flow going where it needs to." Z
I just completed 10,000 miles without this poorly manufactured item. I live in the southeast. Absolutely no issues with aerodynamics, fuel efficiency or engine temp control.
Okay. But it was done for a specific reason, and while that issue might be of relatively small impact compared to other issues, it is good to keep it there. If a part is low cost enough, why not replace what fell off?
Regardless, if you do not care about this, then you can most certainly do whatever you want with your car!
Again, my recommendation remains: replace it. But, the choice is indeed yours!
Z
