The first issue was a leak in the engine fan fluid system ( hydrolic system that powers the radiator fan). It had a bad leak and after a little bit of diagnosing we figured out it was the water pump. So we replaced the water pump and it seemed to be fine for a while but recently it started leaking a lot. For some reason there seems to be a claug or just too much pressure in the system and the fluid just rapidly squirts out of a pipe going out from the pump but only while the car is on. I'm new to this kind of stuff so currently I have no ideas on how to fix this
and any ideas would help. Here is a picture of the leak as well as a diagram of the system. The red circle is where the leak is.
The second issue started after about a month. One day we were driving home with the windows rolled down and when we got home we tried to roll the windows up but when I pressed the switch nothing happened. None of the windows would roll down from any switch. About a week later it worked long enough to get the windows back up but since then it has not worked at all. The powerlocks as well as the sunroof and moving the seats also stopped working. My first thought was to check all the relays and fuses but none of them were bad(in the interior fuse box as well as the fuse box in traffic engine bay) so I asked a couple people about it and they had no idea what could be causing it.
