Waders wrote:Thanks man,
I guess the only way is to just put a cone filter instead of the box filter.
Well, if you mean the K&N oiled filter, then I would recommend you please do a search at NICO for posts on our experience with that filter on Nissan / Infiniti engines.
Yes, some people have been fine with them, but many have found that the micro-droplets of oil that get injected into the air-stream from these oiled filters (no matter how "dry" you make it), have a long-term detrimental effect on the hot-wire MAF sensors on these engines. This can lead to engine drivability problems that are only cured with a replacement of the MAF - simple cleaning of the MAF does not usually fix the issues.
Again, the minor gain is not worth the problems it can cause.
About the only thing you could do for better performance - and quite dramatic too! - would be to look for the
rare Supercharger (or was it Turbocharger?) made by Keuylian Motors for the 2002 Q45 - this
should also fit our 2003 M45, but might need some work to do so.
If you find one of these, the horsepower and torque gains would be totally awesome!
Z
