psychodiagnostik »
https://forums.nicoclub.com/psychodiagnostik-u78276.html
Sat Nov 30, 2013 5:25 pm
So three times in as many weeks, I've been driving at a steady speed & the engine loses all power. The RPMs just drop to idle.
The odd thing is, the engine doesn't sputter or misfire, just returns to a clean even 900 rpm idle or so. After 10 seconds or so, while I'm frantically stepping on the accelerator, the engine responds again as if nothing happened. It's strange that the engine doesn't cut off. It's like the throttle blades suddenly return to idle position & lose all connection to the accelerator pedal for a few seconds.
Oddly enough, there's no CEL & no codes (I had to have the yearly inspection after the 2nd incident; & there were no stored codes). So there's no diagnosis for the shop to do except drive it & try to replicate, however even then I'm not sure how they'd proceed with no codes.
Could this be the camshaft/crankshaft position sensor? I've read the threads about this however there seems to always be a CEL. Also are the '03/04 models included in the recall for the soldier joints for these sensor electronics? I'm calling the dealer after the long weekend, I was just wondering.
thx!
