ronez82 »
https://forums.nicoclub.com/ronez82-u77811.html
Thu Feb 26, 2009 4:31 pm
In the process of doing the Boon MP3 player adaption to the Cassette player, I checked fitment as between the two units and they will fit into each others location. The problem is making the two harnesses reach the new locations. I did not investigate much if there is enough wire to reach, otherwise you can cut off the harnesses and add extensions to them and it will work out great it will just be a lot of wires you will be cutting and splicing. Good Luck.
