2003 M45 Brake Help
MSeries61996
Car: 2003 Infiniti M45 (Y34)
Hi guys.
Question:
When I remove the rear caliper and brake assembly from the rotor, do I need to bleed the brakes? I'm trying to replace the studs/lugs in the hub as I snapped one trying to change a flat.
Any tips advice would be greatly appreciated.
Ilya
If you don't disconnect the line on the caliper, you do not need to bleed the system as you are not introducing air. If you remove the line from the caliper, then yes, you will need to bleed.
