2003 M45 Airbag warning light. I see this is a problem with the car, any help?
SHREVE66
Car: 2003 M45
I had my car checked at the dealer and they told me that I may have an open wire. There is an intermittent open in the circuit, whether it is in the wiring or in the component. They reset the code and couldn't duplicate it. They tried to troubleshoot it, but no results. Has anyone else had this similar problem.
xerexabante
Car: '02 Infiniti Q45
'02 Nissan Maxima SE
There is a TSB on that. But if you don't have anymore codes then they can't fix it. I had that problem before and they did under warranty.
SHREVE66
Car: 2003 M45
tsb?
xerexabante
Well I thought I looked incorrectly and you don't have a recall on your airbag light. Nut you mght need to bring it to the dealer to get fixed hopefully you are under warranty.
TSB= Technical Service Bulletin
SHREVE66
Car: 2003 M45
my question now is, does anyone know of other 03 m45s with my problem
Boon
Car: 03 M45 Black on Black Crime
Well I have just brought my 03 M45 into the dealer today for Airbag issue. Not sure exactly what the problem is but luckily the restraint system is covered 6yr/70k miles. If you have problems get it in. I will post with what exactly the problem was.
I also am having the Fuel Gauge problem.
SHREVE66
Car: 2003 M45
Damn, the dealer is saying my car isnt under warranty. Where did you find the warranty for 6yrs/70k?
Boon
That was straight from the dealer. It is covered under the Vehicle Restraint System warranty. Go to a different dealer that knows what they are doing. Or call Infinity Corporate.
Infinity Consumer Affairs 800.662.6200
Here is your warranty manual for an 03. Page 6 shows that the Restraint System is covered under the Powertrain Warranty. This is your entire warranty manual, print it out and throw it in their face!!!
http://www.infiniti.com/pdf/ow...3.pdf
Modified by Boon at 4:07 PM 2/22/2008
Modified by Boon at 4:09 PM 2/22/2008
SHREVE66
Car: 2003 M45
Damn, thanks a lot. I will do that. I called the dealer and they told me it would not be covered, but now that I have this, I think things will change.
mahmudb
Car: 97' BMW 740il, 03' Infiniti M45
I had my airbag light go on in my M45 and my indy took out the passenger side airbag switch and cleaned and it cleared the code. It hasn't come back since. I also had the fuel gauge problem and they replaced the instrument cluster under my extended warranty.
SHREVE66
Car: 2003 M45
damn,that is good info, but what happens with the fuel gage?
SHREVE66
Car: 2003 M45
Dude, you are the best. I called that number you gave me and was instructed to call the dealer back. So, I called the dealer back and all of a sudden, it is under warranty. I owe you big time. thx
szh
Car: 2018 Tesla Model 3.
Good Stuff™!
Thanks for the help ... certainly good to know about that warranty link.
Z
SHREVE66
Car: 2003 M45
did you ever find the problem with you car?
Boon
Yep. It was the driver side module. Dealer replaced it under warranty and gave me a free G35x for the weekend while they had it. Out of pocket expense= $0.
SHREVE66
Car: 2003 M45
wow, thanks for the info, and that is so cool they gave you the free rental. I bet a weekend in the G made you really appreciate the M that much more. Thanks again
Boon
NP. Car looks good in the avatar. Got any full size pics of it? If so post em up.
SHREVE66
Car: 2003 M45
they are 22's,made by Verde. I chose them because they are very close to stock and got a hell of a good deal on them. paid 2k for them and 300 to lift the car a little.
Boon
Looking good. Those 20's? What kind are they? They look nice cause they are close to stock look but have a bit more going on.
