2003 instrument cluster bulb size LED
stagnet04
I want to upgrade my instrument cluster to LED for the gauges but it looks like my cluster is different from most others. Does anyone know the bulb size to use? It’s not 74 because I took out a few bulbs and they look half the size of the 74. Also if you look at the pic it shows only 3 black screws for bulbs, I’m guessing those are for the gauges. The others are brown and I see those are for the turn signals. Anyone who has a 2003 + and has done an LED upgrade can chime in on this would be awesome.
Bulb next to a wheel weight
R50JR
Car: 03 pathfinder le
stagnet04
astrorami wrote:
Mon Feb 26, 2018 4:09 pm
topic563777.html
I checked that thread before I posted this one because it doesn’t say what size bulb the 2003 has. It’s specific to only up to 2002. Basically everything is 74 bulbs on that thread, but when I pulled mine out, it’s clearly smaller. Anyone?
R50JR
you're certain it isn't a 74?
check out this link.. https://www.superbrightleds.com/moreinf ... l-led/709/
they look similar. do you have better photos of bulb?
