TxGuy67 wrote:Wow Z! You bought the good one and I have the "bad seed" same mfg date for mine. Guess since mine was shipped all the way to Texas....
I think my good result has to do a lot with the over-kill (some might call crazy ) approach I take to early vehicle maintenance. This involves multiple early(*) oil and filter changes, many revs to high rpm's to seat the piston rings properly - even during the "break-in" period - and regular oil and filter changes after that.
I use Mobil 1 0W-40 synthetic now, every 3750 miles, after I finished the initial 7.5k to 10k miles of good dino oil (like Castrol GTX 5W-30). I forget the exact mileage I switched over, but it is in some earlier thread of mine!
Z
(*)In regard to early engine maintenance, in some Mercedes's for example, their recommendation was for an oil and filter change at 100 miles! I did not do it that early, but ... you can search for a post of mine about my early fluid changes!
I changed out the transmission fluid, the differential fluid, power steering fluid, fan fluid (yes, there is such a thing on the M45 - the service consultant did not know about it either!), engine oil (multiple times), radiator fluid, etc., etc., etc. ... within the first 10k miles ... at various times.
