2003 infiniti M45 Crank no start
FLEETVDO
Car: Infiniti M45
Help! When I turn the key on I hear the fuel pump for about 2 seconds. Cranks but does not start.Seems like a fuel issue. I squirt some starting fluid in the air box and it does run for a few seconds. My car has 66k out of warranty. Has ayone else had this problem? Or have any idea?
Mark [email protected]
Modified by FLEETVDO at 9:29 AM 6/3/2007
auditech10
Car: 03 M45
Are there any lights on the dash that come on or flash when you turn the key to crank? It could possibly be that your key lost the security programming and therefore wont start the engine. Or your fuel pump could be shot, or a number of other things.good luck
FLEETVDO
Car: Infiniti M45
No lights on! Not the key! Car runs on starting fluid. I think it is the fuel pump I am not sure. Anbody have any idea??? Or has had this problem?
nmgoodthing
Car: Brilliant Silver 2003 M45 / Pine Silver 2004 Lexus GX470 / Black 93 300zx TT
This may sound dumb but are you sure you have gas? It's a known problem for the gas gauge to read half a tank and be empty.
FLEETVDO
Car: Infiniti M45
Yes, It does seem like it is ouf fuel. I have also had issues with the gas gauge and have run out a few times when the gauge says that I have a 1/4 left. I put 6 gallons in.Somebody must have had this problem!
Q45tech
I'm surprised you didn't purchase Nissan extended warranty..........the drive train warranty is 6 years/70,000 miles.............the comprehesive is 4/60k.
http://www.infiniti.com/pdf/ow...3.pdfThis warranty does not cover damage, failures or corrosionresulting from:• Lack of performance of proper maintenance services as outlinedin your Owner’s Manual.• Use of improper or dirty fuel, fluids or lubricants.• Use of parts not equivalent in quality or design to partssupplied by Nissan for use on Infiniti vehicles.4-year/60,000-mile Basic coverage 5-year/50,000-mile Emission Control coverage 6-year/70,000-mile Powertrain coverage 7-year/unlimited-mileage Corrosion coverage 10-year/unlimited-mileage Seat Belt Warranty 4-year/60,000-mile Genuine Infiniti Accessories Basic coverage (when purchased at time of vehicle sale) Up to 7-year/100,000-mile Infiniti Extended Protection Plan (optional) 2-year/24,000-mile Federal Emission Performance Warranty 4-year/60,000-mile Federal Emission Defect Warranty 8-year/80,000-mile Federal Emission Long Term Defect Warranty 4-year/60,000-mile California Emission Performance and Defect Warranties 7-year/70,000-mile California Emission Long Term Defect W
auditech10
Car: 03 M45
Well if you've run out of gas before and possibly this time as well, you could have fried the pump. If you've put fuel in and it supposedly starts on starting fluid then that is a likely cause for this problem. And what is the point of using exclamation points when giving symptoms or telling us things. If you want help online where nobody has the opportunity to actually look at the car then you are going to have to give us every and all information that may pertain to the situation!!!
