the converted »
https://forums.nicoclub.com/the-converted-u57671.html
Tue Jun 29, 2010 11:03 am
I've was hunting issues like this on my car for a while. First things first, if you think you have bad gas, go and get some isopropyl alcohol and put it in your tank. If there is any water in there, it will help it blend with the gas.
Then looking at the 0303 code, that's the middle cylinder in the back that is showing a misfire. I usually would take the plug and the coil from that cylinder replace them with one from the front bank that is working well and then take the "bad" coil and plug and split them up. If the code stays in the same place, you have a wiring issue, otherwise it will move to the cylinder that has the bad component which would most likely be the coil.
Your 0430 code is for the front bank pre-cat being below threshold. It does occasionally happen that this is a bad o2 sensor, so being the price difference between the sensor and a new cat, I would try replacing the sensor first to see if the problem goes away. Since you have 115k on your car, it's about time that the o2 sensors can start failing.
Welcome to NICO, and let us know how things turn out.
