Component Description:1. FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY Bulletin Number: EC -08-004 Bulletin Date: AUG 2008 Vehicle: 2003 Infiniti G35 Summary:INFINITI: HARD TO FILL FUEL TANK. THE FUEL TANK IS DIFFICULT TO FILL MORE THAN 1/2. NOTE: FILLING NOZZLE CONTINUES TO CLICK OFF WHEN THE FUEL TANK IS MORE THAN 1/2 FULL. ( NHTSA ITEM NUMBER - 10025971 )
Component Description:2. FUEL SYSTEM, OTHER:STORAGE:TANK ASSEMBLY Bulletin Number: EC -08-004 Bulletin Date: AUG 2008 Vehicle: 2003 Infiniti G35 Summary:INFINITI: HARD TO FILL FUEL TANK. THE FUEL TANK IS DIFFICULT TO FILL MORE THAN 1/2. NOTE: FILLING NOZZLE CONTINUES TO CLICK OFF WHEN THE FUEL TANK IS MORE THAN 1/2 FULL. ( NHTSA ITEM NUMBER - 10025971 )
Component Description:3. EQUIPMENT:OTHER:OWNERS/SERVICE/OTHER MANUAL Bulletin Number: ITB 05-051 Bulletin Date: JUL 2008 Vehicle: 2003 Infiniti G35 Summary:AIR FLOW METER SERVICE. ( NHTSA ITEM NUMBER - 10025704 )
Component Description:4. EXTERIOR LIGHTING Bulletin Number: 03031 Bulletin Date: APR 2007 Vehicle: 2003 Infiniti G35 Summary:EXTERIOR LAMP FOGGING. ( NHTSA ITEM NUMBER - 10021509 )
Component Description:5. STEERING:WHEEL AND HANDLE BAR Bulletin Number: 07008 Bulletin Date: FEB 2007 Vehicle: 2003 Infiniti G35 Summary:MANUAL TILT ADJUSTMENT LEVER REPAIR PROCEDURE. ( NHTSA ITEM NUMBER - 10021344 )
Component Description:6. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 06004 Bulletin Date: MAR 2006 Vehicle: 2003 Infiniti G35 Summary:MALFUNCTION INDICATOR LAMP WITH DIAGNOSTIC TROUBLE CODE U1000 OR U1010 STORED IN ENGINE CONTROL UNIT. 2002 - 2006 INFINITI VEHICLES WITH CAN COMMUNICATION. ( NHTSA ITEM NUMBER - 10019293 )
Component Description:7. SERVICE BRAKES, AIR:ANTILOCK:WHEEL SPEED SENSOR Bulletin Number: 03056A Bulletin Date: NOV 2005 Vehicle: 2003 Infiniti G35 Summary:ESSENTIAL TOOL J-45741-INF ABS ACTIVE WHEEL SENSOR CHECKER. ( NHTSA ITEM NUMBER - 10006124 )
Component Description:8. POWER TRAIN:AXLE ASSEMBLY Bulletin Number: 05002 Bulletin Date: NOV 2005 Vehicle: 2003 Infiniti G35 Summary:CLICKING NOISE FROM REAR AXLES. ( NHTSA ITEM NUMBER - 10017773 )
Component Description:9. SEATS Bulletin Number: 02080 Bulletin Date: JUL 2005 Vehicle: 2003 Infiniti G35 Summary:DRIVER'S SEAT NOISE AND/OR ROCKS BACK AND FORTH. ( NHTSA ITEM NUMBER - 10016401 )
Component Description:10. POWER TRAIN:AXLE ASSEMBLY Bulletin Number: 05002 Bulletin Date: JUL 2005 Vehicle: 2003 Infiniti G35 Summary:CLICKING NOISE IS COMING FROM THE LEFT AND/OR RIGHT REAR AXLE WHEN ACCELERATING FROM A STOP. ( NHTSA ITEM NUMBER - 10016567 )
Component Description:11. STRUCTURE:BODY Bulletin Number: 05034 Bulletin Date: JUN 2005 Vehicle: 2003 Infiniti G35 Summary:NOISE FROM REAR DOOR WITH WINDOW ALL THE WAY UP. ( NHTSA ITEM NUMBER - 10015415 )
Component Description:12. ELECTRICAL SYSTEM:WIRING Bulletin Number: 04020 Bulletin Date: MAR 2005 Vehicle: 2003 Infiniti G35 Summary:TRAILER LIGHT WIRING. TO INCLUDE INFINITI 2006 M35/M45. ( NHTSA ITEM NUMBER - 10012880 )
Component Description:13. STEERING Bulletin Number: 03028A Bulletin Date: SEP 2004 Vehicle: 2003 Infiniti G35 Summary:STEERING DRIFT TO THE RIGHT. ( NHTSA ITEM NUMBER - 10005686 )
Component Description:14. VISIBILITY:REARVIEW MIRRORS/DEVICES Bulletin Number: 04046 Bulletin Date: SEP 2004 Vehicle: 2003 Infiniti G35 Summary:RATTLE NOISE FROM REAR VIEW MIRROR HARNESS COVER. ( NHTSA ITEM NUMBER - 10009749 )
Component Description:15. STRUCTURE:BODY Bulletin Number: 03052 Bulletin Date: SEP 2004 Vehicle: 2003 Infiniti G35 Summary:SQUEAK AND RATTLE REPAIR. COUPE ONLY. ( NHTSA ITEM NUMBER - 10003435 )
Component Description:16. STRUCTURE:BODY Bulletin Number: 04035 Bulletin Date: AUG 2004 Vehicle: 2003 Infiniti G35 Summary:RATTLE NOISE FROM REAR SIDE WINDOW FINISHER. ( NHTSA ITEM NUMBER - 10009175 )
Component Description:17. EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM) Bulletin Number: 04042 Bulletin Date: AUG 2004 Vehicle: 2003 Infiniti G35 Summary:NAVIGATION SYSTEM IS INOPERATIVE AND THE DISPLAY SHOWS DISC ERROR OR DVD-ROM VERSION IS NOT CORRECT. ( NHTSA ITEM NUMBER - 10009182 )
Component Description:18. VISIBILITY:POWER WINDOW DEVICES AND CONTROLS Bulletin Number: 04033 Bulletin Date: JUL 2004 Vehicle: 2003 Infiniti G35 Summary:WINDOW REGULATOR MOTOR RESET PROCEDURE. ( NHTSA ITEM NUMBER - 10009364 )
Component Description:19. VISIBILITY:SUN ROOF ASSEMBLY Bulletin Number: 04024 Bulletin Date: MAY 2004 Vehicle: 2003 Infiniti G35 Summary:SUNROOF LID SQUEAK/CREAK NOISE. ( NHTSA ITEM NUMBER - 10007679 )
Component Description:20. INTERIOR LIGHTING Bulletin Number: 04019 Bulletin Date: APR 2004 Vehicle: 2003 Infiniti G35 Summary:VANITY MIRROR MIRROR BULB REPLACEMENT. ( NHTSA ITEM NUMBER - 10007728 )
Component Description:21. ELECTRICAL SYSTEM:WIRING Bulletin Number: 04020 Bulletin Date: APR 2004 Vehicle: 2003 Infiniti G35 Summary:APPROPRIATE HOOKUP POINTS FOR CONNECTING A TRAILER LIGHTS WIRING HARNESS TO THE VEHICLE. ( NHTSA ITEM NUMBER - 10007727 )
Component Description:22. ELECTRICAL SYSTEM Bulletin Number: 03055 Bulletin Date: FEB 2004 Vehicle: 2003 Infiniti G35 Summary:BUZZ SOUND FROM METER CLUSTER AFTER IGNITION KEY IS TURNED OFF / TURN SIGNAL AND WARNING CHIME DO NOT SOUND. THIS REPLACES ITB03-055 DATED 8/20/03. ( NHTSA ITEM NUMBER - 10003514 )
Component Description:23. STRUCTURE:BODY Bulletin Number: 03052A Bulletin Date: JAN 2004 Vehicle: 2003 Infiniti G35 Summary:SQUEAK AND RATTLE REPAIR. COUPE ONLY. ( NHTSA ITEM NUMBER - 10005688 )
Component Description:24. STRUCTURE:BODY Bulletin Number: 03050A Bulletin Date: JAN 2004 Vehicle: 2003 Infiniti G35 Summary:SQUEAK AND RATTLE REPAIR. SEDAN ONLY. ( NHTSA ITEM NUMBER - 10005687 )
Component Description:25. SERVICE BRAKES, HYDRAULIC Bulletin Number: 03069A Bulletin Date: JAN 2004 Vehicle: 2003 Infiniti G35 Summary:REDUCTION OF FRONT BRAKE NOISE WHEN BRAKING IN REVERSE. THIS BULLETIN REPLACES ITB03-069. ( NHTSA ITEM NUMBER - 10005216 )
Component Description:26. EQUIPMENT Bulletin Number: 04001 Bulletin Date: JAN 2004 Vehicle: 2003 Infiniti G35 Summary:REMOTE KEYLESS ENTRY REPLACEMENT PARTS. ( NHTSA ITEM NUMBER - 10005194 )
Component Description:27. STRUCTURE:BODY:DOOR Bulletin Number: 03071 Bulletin Date: DEC 2003 Vehicle: 2003 Infiniti G35 Summary:RATTLE OR CREAK NOISE FROM TOP OF DOOR WINDOW FRAME. ( NHTSA ITEM NUMBER - 10005263 )
Component Description:28. INTERIOR LIGHTING Bulletin Number: 03065 Bulletin Date: NOV 2003 Vehicle: 2003 Infiniti G35 Summary:CLOCK BULB REPLACEMENT. VARIOUS MODELS INCLUDING 2004 I35. ( NHTSA ITEM NUMBER - 10004598 )
Component Description:29. VISIBILITY:GLASS, SIDE/REAR Bulletin Number: 03058B Bulletin Date: OCT 2003 Vehicle: 2003 Infiniti G35 Summary:POP OR TICK NOISE FROM FRONT DOOR WINDOW GLASS. ( NHTSA ITEM NUMBER - 10004562 )
Component Description:30. VISIBILITY:SUN ROOF ASSEMBLY Bulletin Number: 03060 Bulletin Date: OCT 2003 Vehicle: 2003 Infiniti G35 Summary:SUNROOF INOPERATIVE. 2004 FX35/FX45 INCLUDED. ( NHTSA ITEM NUMBER - 10003951 )
Component Description:31. VISIBILITY:GLASS, SIDE/REAR Bulletin Number: 03058A Bulletin Date: SEP 2003 Vehicle: 2003 Infiniti G35 Summary:POP OR TICK NOISE FROM FRONT DOOR WINDOW GLASS. ( NHTSA ITEM NUMBER - 10003913 )
Component Description:32. ELECTRICAL SYSTEM Bulletin Number: 03020B Bulletin Date: SEP 2003 Vehicle: 2003 Infiniti G35 Summary:MALFUNCTION INDICATOR LAMP (MIL) ON DIAGNOSTIC TROUBLE CODE (DTC) P0442 (EVAP SMALL LEAK) AND/OR P0456 (EVAP VERY SMALL LEAK) STORED IN SELF DIAGNOSIS RESULTS. ( NHTSA ITEM NUMBER - 10003916 )
Component Description:33. EQUIPMENT:ELECTRICAL:AIR CONDITIONER Bulletin Number: 02056A Bulletin Date: SEP 2003 Vehicle: 2003 Infiniti G35 Summary:NOISE FROM ENGINE AREA WITH AIR CONITIONER ON. ( NHTSA ITEM NUMBER - 10003595 )
Component Description:34. SEAT BELTS:FRONT Bulletin Number: ITB99016B Bulletin Date: AUG 2003 Vehicle: 2003 Infiniti G35 Summary:FRONT SEAT BELT LATCH PLATE RETAINING BUTTON MISSING. VARIOUS MODELS INCLUDING THE 2004 G35. ( NHTSA ITEM NUMBER - 10003519 )
Component Description:35. SEATS:MID/REAR ASSEMBLY Bulletin Number: 03046 Bulletin Date: JUL 2003 Vehicle: 2003 Infiniti G35 Summary:A CREAK / SQUEAK NOISE FROM REAR SEAT AREA. ( NHTSA ITEM NUMBER - 10002937 )
Component Description:36. STRUCTURE:BODY Bulletin Number: 03050 Bulletin Date: JUL 2003 Vehicle: 2003 Infiniti G35 Summary:SQUEAK AND RATTLE REPAIR. SEDAN ONLY. ( NHTSA ITEM NUMBER - 10003454 )
Component Description:37. EQUIPMENT:ELECTRICAL:AIR CONDITIONER Bulletin Number: 03045 Bulletin Date: JUL 2003 Vehicle: 2003 Infiniti G35 Summary:NOISE FROM ENGINE AREA OR AIR CONDITIONER NOT COLD DUE TO BROKEN DRIVE BELT. ( NHTSA ITEM NUMBER - 10002936 )
Component Description:38. STRUCTURE:FRAME AND MEMBERS Bulletin Number: 03023A Bulletin Date: JUL 2003 Vehicle: 2003 Infiniti G35 Summary:RATTLE FROM THE REAR PARCEL SHELF. COUPE. ( NHTSA ITEM NUMBER - 10003457 )
Component Description:39. STRUCTURE:FRAME AND MEMBERS Bulletin Number: 03017A Bulletin Date: JUL 2003 Vehicle: 2003 Infiniti G35 Summary:REAR PARCEL SHELF BUZZ OR RATTLE. ( NHTSA ITEM NUMBER - 10003437 )
Component Description:40. ELECTRICAL SYSTEM Bulletin Number: 03020A Bulletin Date: JUN 2003 Vehicle: 2003 Infiniti G35 Summary:MALFUNCTION INDICATOR LAMP (MIL) ON DIAGNOSTIC TROUBLE CODE (DTC) P0442 (EVAP SMALL LEAK) AND/OR P0456 (EVAP VERY SMALL LEAK) STORED IN SELF DIAGNOSIS RESULTS. ( NHTSA ITEM NUMBER - 10003351 )
Component Description:41. SEATS:FRONT ASSEMBLY:SEAT HEATER/COOLER Bulletin Number: 061003 Bulletin Date: JUN 2003 Vehicle: 2003 Infiniti G35 Summary:SEAT HEATER HARNESS VOLUNTARY SERVICE CAMPAIGN REPAIR INSTRUCTIONS MODIFICATION. ( NHTSA ITEM NUMBER - 10002087 )
Component Description:42. EQUIPMENT:ELECTRICAL:NAVIGATIONAL SYSTEM(GLOBAL POSITIONING SYSTEM) Bulletin Number: 03026 Bulletin Date: JUN 2003 Vehicle: 2003 Infiniti G35 Summary:NAVIGATION SYSTEM STUCK ON PLEASE WAIT SCREEN. ( NHTSA ITEM NUMBER - 10003335 )
Component Description:43. STRUCTURE:FRAME AND MEMBERS Bulletin Number: 03023 Bulletin Date: APR 2003 Vehicle: 2003 Infiniti G35 Summary:RATTLE FROM THE REAR PARCEL SHELF. COUPE. ( NHTSA ITEM NUMBER - 10001445 )
Component Description:44. STEERING Bulletin Number: 03028 Bulletin Date: APR 2003 Vehicle: 2003 Infiniti G35 Summary:STEERING DRIFT TO THE RIGHT. ( NHTSA ITEM NUMBER - 10001676 )
Component Description:45. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 03020 Bulletin Date: APR 2003 Vehicle: 2003 Infiniti G35 Summary:MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P0442 (EVAP SMALL LEAK) AND/OR P0456 (EVAP VERY SMALL LEAK) STORED IN SELF DIAGNOSIS RESULTS. ( NHTSA ITEM NUMBER - 10002202 )
Component Description:46. VISIBILITY:GLASS, SIDE/REAR Bulletin Number: 03021 Bulletin Date: APR 2003 Vehicle: 2003 Infiniti G35 Summary:GREASE MARK OR STREAK ON INSIDE OF DOOR GLASS. ( NHTSA ITEM NUMBER - 10001677 )
Component Description:47. SEATS Bulletin Number: 03018 Bulletin Date: MAR 2003 Vehicle: 2003 Infiniti G35 Summary:DRIVER'S SEAT COMFORT IMPROVEMENT. ( NHTSA ITEM NUMBER - 10001258 )
Component Description:48. ELECTRICAL SYSTEM Bulletin Number: 03007A Bulletin Date: MAR 2003 Vehicle: 2003 Infiniti G35 Summary:VOLUNTARY SERVICE CAMPAIGN AUDIO FINISHER CIRCUIT BOARD. ( NHTSA ITEM NUMBER - 10001253 )
Component Description:49. STRUCTURE:FRAME AND MEMBERS Bulletin Number: 03017 Bulletin Date: MAR 2003 Vehicle: 2003 Infiniti G35 Summary:REAR PARCEL SHELF BUZZ OR RATTLE. ( NHTSA ITEM NUMBER - 10001256 )
Component Description:50. ELECTRICAL SYSTEM Bulletin Number: 03014 Bulletin Date: FEB 2003 Vehicle: 2003 Infiniti G35 Summary:SLIP AND VDC OFF LIGHTS ON WITH C1145 YAW RATE SENSOR STORED. ( NHTSA ITEM NUMBER - 10001249 )
Component Description:51. ELECTRICAL SYSTEM Bulletin Number: 03007 Bulletin Date: FEB 2003 Vehicle: 2003 Infiniti G35 Summary:VOLUNTARY SERVICE CAMPAIGN AUDIO FINISHER CIRCUIT BOARD. ( NHTSA ITEM NUMBER - 10001246 )
Component Description:52. ELECTRICAL SYSTEM Bulletin Number: ITB03007 Bulletin Date: FEB 2003 Vehicle: 2003 Infiniti G35 Summary:VOLUNTARY SERVICE CAMPAIGN AUDIO FINISHER CIRCUIT BOARD. ( NHTSA ITEM NUMBER - 10001162 )
Component Description:53. EXTERIOR LIGHTING:HEADLIGHTS Bulletin Number: 03001 Bulletin Date: JAN 2003 Vehicle: 2003 Infiniti G35 Summary:VOLUNTARY RECALL CAMPAIGN - HEADLAMP ADJUSTER CAP INSTALLATION. ( NHTSA ITEM NUMBER - 10001023 )
Component Description:54. SERVICE BRAKES, HYDRAULIC Bulletin Number: 03006 Bulletin Date: JAN 2003 Vehicle: 2003 Infiniti G35 Summary:SQUEAK OR SQUEAL NOISE COMING FROM REAR BRAKES. ( NHTSA ITEM NUMBER - 10000972 )
Component Description:55. SERVICE BRAKES, HYDRAULIC Bulletin Number: 03006 Bulletin Date: JAN 2003 Vehicle: 2003 Infiniti G35 Summary:REAR BRAKE NOISE. ( NHTSA ITEM NUMBER - 10001181 )
Component Description:56. POWER TRAIN:MANUAL TRANSMISSION Bulletin Number: 03003 Bulletin Date: JAN 2003 Vehicle: 2003 Infiniti G35 Summary:MANUAL TRANSMISSION SHIFT KNOB NOT STRAIGHT. ( NHTSA ITEM NUMBER - 10001026 )
Component Description:57. POWER TRAIN:AUTOMATIC TRANSMISSION Bulletin Number: 02074A Bulletin Date: JAN 2003 Vehicle: 2003 Infiniti G35 Summary:AUTOMATIC TRANSMISSION HARSH SHIFT WITH DIAGNOSTIC TROUBLE CODE (DTC) P1710 AND P1716 STORED. ( NHTSA ITEM NUMBER - 10000971 )
Component Description:58. STRUCTURE:BODY:ROOF AND PILLARS Bulletin Number: 03004 Bulletin Date: JAN 2003 Vehicle: 2003 Infiniti G35 Summary:HEADLINER SAGGING AT REAR OF SUNROOF. ( NHTSA ITEM NUMBER - 10001027 )
Component Description:59. INTERIOR LIGHTING Bulletin Number: 02081 Bulletin Date: DEC 2002 Vehicle: 2003 Infiniti G35 Summary:INTERIOR COURTESTY LAMPS INOPERATIVE. ( NHTSA ITEM NUMBER - 10000795 )
Component Description:60. POWER TRAIN:AUTOMATIC TRANSMISSION Bulletin Number: 02074 Bulletin Date: DEC 2002 Vehicle: 2003 Infiniti G35 Summary:AUTOMATIC TRANSMISSION HARSH SHIFT WITH DIAGNOSTIC TROUBLE CODE P1710 AND P1716 STORED. ( NHTSA ITEM NUMBER - 10000019 )
Component Description:61. WHEELS Bulletin Number: 02073 Bulletin Date: NOV 2002 Vehicle: 2003 Infiniti G35 Summary:TITANIUM FINISH ALUMINUM WHEELS. ( NHTSA ITEM NUMBER - 10000411 )
Component Description:62. EQUIPMENT:ELECTRICAL Bulletin Number: 02072 Bulletin Date: NOV 2002 Vehicle: 2003 Infiniti G35 Summary:AMBIENT TEMPERATURE SENSOR DISPLAY INACCURATE. ( NHTSA ITEM NUMBER - 10000410 )
Component Description:63. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 02010A Bulletin Date: NOV 2002 Vehicle: 2003 Infiniti G35 Summary:ENGINE WILL NOT START. VEHICLE IMMOBILIZER SYSTEM/NISSAN ANTI-THEFT SYSTEM (IVIS/NATS). ( NHTSA ITEM NUMBER - 10000406 )
Component Description:64. POWER TRAIN:AUTOMATIC TRANSMISSION Bulletin Number: 02064 Bulletin Date: OCT 2002 Vehicle: 2003 Infiniti G35 Summary:REPLACEMENT AUTOMATIC TRANSMISSION REQUESTS NEW STYLE AUTOMATIC TRANSMISSION FLUID FILLER TUBE. ( NHTSA ITEM NUMBER - 10000213 )
Component Description:65. ENGINE AND ENGINE COOLING:ENGINE:GASOLINE Bulletin Number: ITB02056 Bulletin Date: OCT 2002 Vehicle: 2003 Infiniti G35 Summary:INFORMATION REGARDING A BUZZ OR GROWL TYPE NOISE FROM THE ENGINE AREA WITH THE AIR CONDITIONER ON WHICH GOES AWAY WHEN THE AIR CONDITIONER IS OFF. ( NHTSA ITEM NUMBER - 635644 )
Component Description:66. ELECTRICAL SYSTEM:BATTERY Bulletin Number: ITB02055 Bulletin Date: OCT 2002 Vehicle: 2003 Infiniti G35 Summary:INFORMATION ON COUPE BATTERY SERVICE PRECAUTIONS. ( NHTSA ITEM NUMBER - 635643 )
Component Description:67. SEAT BELTS:FRONT:BUCKLE ASSEMBLY Bulletin Number: 02067 Bulletin Date: OCT 2002 Vehicle: 2003 Infiniti G35 Summary:FRONT SEAT BELT BUCKLE BRACKET CAUSING CLICKING NOISE. ( NHTSA ITEM NUMBER - 10000212 )
Component Description:68. EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC. Bulletin Number: 02062 Bulletin Date: OCT 2002 Vehicle: 2003 Infiniti G35 Summary:AUDIO MATRIX. ( NHTSA ITEM NUMBER - 10000215 )
Component Description:69. EQUIPMENT:ELECTRICAL:AIR CONDITIONER Bulletin Number: 02056 Bulletin Date: OCT 2002 Vehicle: 2003 Infiniti G35 Summary:BUZZ OR GROWL TYPE NOISE FROM ENGINE AREA WITH AIR CONDITIONER ON. ( NHTSA ITEM NUMBER - 10000216 )
Component Description:70. OTHER Bulletin Number: ITB02054 Bulletin Date: SEP 2002 Vehicle: 2003 Infiniti G35 Summary:THIS BULLETIN PROVIDES SERVICE INFORMATION FOR MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P0442 (EVAP SMALL LEAK) STORED. ( NHTSA ITEM NUMBER - 635642 )
Component Description:71. STRUCTURE Bulletin Number: 02028A Bulletin Date: SEP 2002 Vehicle: 2003 Infiniti G35 Summary:CREAK OR RATTLE NOISE FROM THE BASE OF THE WINDSHIELD. ( NHTSA ITEM NUMBER - 10000129 )
Component Description:72. VISIBILITY:WINDSHIELD Bulletin Number: ITB02028A Bulletin Date: SEP 2002 Vehicle: 2003 Infiniti G35 Summary:INFORMATION PERTAINING TO A SQUEAK, CREAK, OR RATTLE NOISE COMING FROM THE CENTER OF THE DASH OR BOTTOM OF THE WINDSHIELD WHILE DRIVING. ( NHTSA ITEM NUMBER - 635640 )
Component Description:73. SUSPENSION Bulletin Number: ITB02060 Bulletin Date: SEP 2002 Vehicle: 2003 Infiniti G35 Summary:SOME VEHICLES MAY EXHIBIT A CREAK NOISE FROM THE FRONT END WHILE DRIVNG OVER ROAD DIPS, RAIN CHANNELS, STREET INTERSECTIONS AND / OR DRIVEWAYS. ( NHTSA ITEM NUMBER - 635647 )
Component Description:74. STRUCTURE:BODY:DOOR Bulletin Number: 02057 Bulletin Date: SEP 2002 Vehicle: 2003 Infiniti G35 Summary:POP OR CLUNK NOISE FROM FRONT DOOR AND / OR WINDOW. ( NHTSA ITEM NUMBER - 10000131 )
Component Description:75. STRUCTURE:BODY Bulletin Number: 02060 Bulletin Date: SEP 2002 Vehicle: 2003 Infiniti G35 Summary:CREAK NOISE FROM FRONT END. ( NHTSA ITEM NUMBER - 10000132 )
Component Description:76. ENGINE AND ENGINE COOLING:ENGINE Bulletin Number: 02054 Bulletin Date: SEP 2002 Vehicle: 2003 Infiniti G35 Summary:MALFUNCTION INDICATOR LIGHT (MIL) ON WITH DIAGNOSTIC TROUBLE CODE (DTC) P0442 (EVAP SMALL LEAK) STORED IN THE ELECTRONIC CONTROL MODULE (ECM). ( NHTSA ITEM NUMBER - 10000130 )
Component Description:77. STRUCTURE:BODY:DOOR Bulletin Number: ITB02057 Bulletin Date: SEP 2002 Vehicle: 2003 Infiniti G35 Summary:INFORMATION ON DIAGNOSING POP OR CLUNK NOISE FROM FRONT DOOR AND / OR WINDOW. ( NHTSA ITEM NUMBER - 635646 )
Component Description:78. STRUCTURE:BODY:DOOR Bulletin Number: ITB02021A Bulletin Date: JUL 2002 Vehicle: 2003 Infiniti G35 Summary:CONCERNS WITH RATTLE OR BUZZ NOISE FROM FRONT DOOR PANEL(S). ( NHTSA ITEM NUMBER - 635047 )
Component Description:79. POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM) Bulletin Number: ITB02017 Bulletin Date: APR 2002 Vehicle: 2003 Infiniti G35 Summary:SUBJECT REGRDING TRANSMISSION CONTROL MODULE (TCM) INITIALIZATION AFTER TRANSMISSION REPLACEMENT. ( NHTSA ITEM NUMBER - 632216 )
Component Description:80. VISIBILITY:WINDSHIELD Bulletin Number: ITB02028 Bulletin Date: APR 2002 Vehicle: 2003 Infiniti G35 Summary:SOME VEHICLES MAY EXHIBIT A SQUEAK, CREAK OR RATTLE NOISE COMING FROM THE BASE OF THE WINDSHIELD. ( NHTSA ITEM NUMBER - 635057 )
Component Description:81. POWER TRAIN Bulletin Number: ITB02019 Bulletin Date: APR 2002 Vehicle: 2003 Infiniti G35 Summary:CONCERNS WITH TACHOMETER NEEDLE ON WRONG SIDE OF STOP PIN. ( NHTSA ITEM NUMBER - 631192 )
Component Description:82. STRUCTURE:BODY:DOOR Bulletin Number: ITB02021 Bulletin Date: APR 2002 Vehicle: 2003 Infiniti G35 Summary:SUBJECT REGARDING RATTLE OR BUZZ NOISE FROM FRONT DOOR PANEL(S). ( NHTSA ITEM NUMBER - 631189 )
