With a cold engine remove radiator cap and fill plastic overflow reservoir to the cold marktobesuccessful wrote:Thanks Joe. How do you bleed it?
If the manual states 9 quarts and there are 4 quarts to a gallon than you need more than 2 gallons.slloyds wrote:If I'm going to drain the coolant just to replace water pump do i really need to buy 2 gallons of antifreeze to refill the system? The Manual says it takes 9 plus quarts.
