loystock »
https://forums.nicoclub.com/loystock-u10145.html
Tue May 04, 2010 10:17 pm
Welcome to NICO.
As in my earlier posting, the Voltage Regulator is inside the alternator and you will not see it unless you disassemble the alternator.
Non-OEM alternator can be problematic. I have had bad experience with such some time ago where I have to replace the alternator 3 times until I go the right one working.
It's possible that the alternator-battery combination are good but you have a wiring issue in you car. Check for any crossed wire (short circuit) on the battery and alternator wiring as well as in the fusible link area. Have you done any electrical modification in your car? It could be drawing too much current or may have a short circuit as it goes thru the firewall, etc.
Make sure your battery connections are clean and tight. Measure the voltage with engine off - it must be > 12.5 VDC. If not, you have a weak battery, loading the alternator. With the engine running, check the alternator charging voltage is >13.8 VDC and steady (not fluctuating). If the alternator output is low, either the alternator is bad or something is loading it down. To check for abnormal load or short circuit, you need an ammeter (clamp type or series type). With engine off, measure the current drain on the battery (parasitic drain is always present since some controllers need power even with engine off). It should be <50uAmps (0.050 Amp). Anything higher than that requires further investigation of your car's wiring.
