This problem occurred randomly this weekend. Out of absolutely nowhere, I wake up Saturday morning and find that my windows are rolled down which was odd since I didn't leave them that way. I turned the car on to ACC, rolled em up, pulled the keys out, and as soon as I opened my door, they rolled back down again.
My troubleshooting basically went like this:ACC, window lock, key out, door open; problem persistedTurned over and started, key out, door open; problem persistedStarted, window lock, ", "; "Removed both battery terminals, replaced terminals, ACC, key out, door open; problem persisted.
So I looked up the issue and found this thread:
zerothread/203704
After looking for this mysterious black switch for a while I gave up. I even removed the door panel completely, but it was no use. The master switch is $50 online, and I will be getting quotes from NAPA and the local dealership soon. Do I really need to replace this switch or is there something else I should look into? $50 isn't the end of the world but I'd rather not spend it if I don't need to.
Any insight would be greatly appreciated!
