gnotaz wrote:The VDC never gives me a chance to correct the steering angle. I attempt to throw the rear end out with power entering the corner. The VDC clamps the throttle and brakes. Strangely, once the VDC has turned off, I can throw the car nearly as sideways as I want without another interruption! It will turn back on only if I get the rear out way too much and try to steer out. It comes back on . Honestly, the rear appears to stick better than the front! Perhaps my perception is incorrect. My Lotus Esprit gives the same sensation without the electronic assists trying to correct my line. Incidentally, the car appears to work perfect with the VDC switched off.
Yeah the tire companies will say that they don't want you to try something else. I read a good three hundred reviews, and did extensive research before I bought my last set of tires, and I'm not that impressed.
The VDC issue your describing is a programming flaw(I'm not saying a problem or anything that can be repaired)that incorporates the wheel speed sensors, steering angle, yaw, and G sensors, the earlier G's lacked a sport setting. It's one of the only things missing from it, definitely takes some of the fun out of driving them.
I really don't think worn pads would really cause that, not definitely but its not too likely. Depending on how much if any break pressure is applied, it should not significantly effect the quality of braking. It sounds more like the variance in composition of the tires, your old ones gripped slightly better keeping the VDC from activating.
A quick Google for any updated VDC control units or software reflash to fix that would change the engagement parameters showed nothing useful. Damn
BTW you cant really compare a daily driver for all age groups to a race ready toy. Although the Lotus is a great choice.
