2003 G35 Sedan running hot
tobesuccessful
Car: 2003 Infiniti G35 Sedan
I smelled antifreeze and noticed that the radiator had a crack in it. I have changed the radiator and it still runs hot. I also changed the thermostat and it still runs hot. There are now no visible leaks. What else could be the problem?
Q451990
It is notoriously difficult to refill the coolant in newer Nissan engines and get all of the air pockets out...
Check out the factory service manual at www.nicoclub.com/FSM/ for the procedure. As a last resort you may have to have it bled by a dealer tech.
Good luck!
Heath
