tcoleman wrote:Just bought wife a G35 sedan and it's time to change the oil. Is this easily done at home? I briefly looked under the car and the entire engine looks like it has a cover over it. Any suggestions, comments greatly appreciated.
It is not difficult to do.
I've done it over thirty times.
I have a Sears 4 ton hydraulic jack, jack stands, ramps, an old pink shower curtain that I place under the car.I believe there are fourteen 10mm bolts to remove the fiberboard shroud.(in photo below)It takes less than three minutes to remove if you have a cordless drill with a 3/8" drive socket adapter.
I can't do it today
Telcoman
Modified by telcoman at 4:33 PM 2/17/2010
