seymore4 »
https://forums.nicoclub.com/seymore4-u197822.html
Sun Mar 25, 2012 4:40 pm
The gears should be exactly the same, but it is true that the newer trannys have stronger parts. I don't know why you would be redlining so soon, it could be an ecu issue, try disconnecting the battery and doing a manual reset, if you want to get an uprev osiris tune PM me for a hookup, you can bump the rev limiter as well as recalibrate the A/F, timing, speed limiter, etc.
