2003 G35 HID (Xenon) Headlight
Orioles1
Car: 2003 G35
Hey guys, new member here. I recently purchased a 2003 G35 sedan and the passenger's side front headlight low beam isn't working. I opened up the bulb housing and took this pic. Is a bulb even in there? https://s16.postimg.org/cbi17pxpx/IMG_2 ... 739956.jpg
13_SkylineSedan
Car: 2x 2013 G37 sedan 2WD-7AT (his and hers)
Your "low beams" are the upper bulb in your headlamp. I'm not sure which one we're looking at in the picture but the bulb there is held in place by that a spring which has a coil to the left of the bulb in your pic. If you pull the connector off, then press that spring down and move it a bit upwards, it will come out of the slot and free the bulb. 2003 could be either Halogen or HID so check page 31 of this book:
http://www.nicoclub.com/manuals/G35/Sedan/2003/lt.pdf
to see if you can tell which you have.
