2003 G35 Fan conversion.
TeflonG35
Car: 2003 G35 Sedan
If you have a mechanical fan on your G then I highly suggest you swap it out for an electric fan. It is far more responsive. Especially with the Unorthodox Racing underdrive pullies. I know this upgrade has been mentioned before but i just installed it and it is a must.
The fan i opted for was the Mishimoto 14in. Performance Slim Radiator Fan. from http://www.americanmuscle.com/....html
Free shipping and came with the mounting kit.
TeflonG35
Car: 2003 G35 Sedan
Pics!!!Fan installed and shroud removed. Lots of space is freed up but the pics were taken with a crappy phone. Some may call this ghetto. I know. But it works and works well. Plus there is a secondary fan if this switch forgets to get pressed.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
aren't there ways of having the fan switch on automatically?
Why did you opt for this fan?
TeflonG35
Car: 2003 G35 Sedan
I'm sure there are ways to make the fans work automaticly. But I could not find information on the forum and ive asked in the past and haven't really got any info useful in the past. Also I was getting frustrated with the fuse box. So i fished wires through where the past owner had an after market amp wire going through. Put on a switch. Mounted the fan and called it a day.
Great fan. Powerful. Keeps it cooler then stock. Also only 5.5 amps. So not a major drain on the alternator.
Also 2 fuses were added in this electronic circuit. One near the battery and one near the switch. Just to keep it safe.
BrandAidDesignG35
Car: 04 Infiniti G35 Sedan
Hey Teflon, You da man!!! I went directly to infiniti parts last week seeking info on a second gen electric motor and fan mounts etc..., I could've set it up with them, but they seem retarded, and don't understand what I'm trying to achieve, or how simple it is...
What's the price for this rig??? I have to do this right away but I'm installing the BLOX spacer and maybe and oil change, and brakes as well, but we'll see how much energy I have later
This mechanical fan business is pissing me off, so close, yet I still feel so far away from getting it all together, and ulike you teflon, I think I'd prefer to have it set automatically, so I'm also trying to find a shop to install a resistor of sorts
joe603
Car: 2014 Durango R/T
It should be wired to the coolant temp. Fans are set to come on at a preset temp, and go off at another. Do some searching online...I'm sure you'll find something!
TeflonG35
Car: 2003 G35 Sedan
BrandAidDesignG35 wrote:Hey Teflon, You da man!!! I went directly to infiniti parts last week seeking info on a second gen electric motor and fan mounts etc..., I could've set it up with them, but they seem retarded, and don't understand what I'm trying to achieve, or how simple it is...
The way I did was just the fan and mounting kit($69.99 from the link I have above). A switch, some wire, and 2 fuses.
I know if you want it to come on automatically then you would have to hook it to a relay. That would cost more and I was getting frustrated. I can always change it later.
It made a huge difference and I recommend to have it with underdrive pulleys. Also A/C comes out much stronger.
tollboothwilley
this is definitely my next mod....i'm just too busy for my car right now
I wish i had more time to get under the car/pop the hood. I'm just too busy during the day and its too hot here in AZ.
