pippen99 »
https://forums.nicoclub.com/pippen99-u73709.html
Tue Jul 20, 2010 11:32 am
Your BCM(body control module) needs to be reset. Unhook the positive cable from your battery and let set for 5 minutes, Reattach the battery cable and your problem should resolved. You will lose your radio presets and any other memory settings you might have. If it solves your problem and the reoccurs your BCM will have to be replace(several hundreds of dollars). Good Luck!
