2003 G35 Bose Audio Parasitic DrainI have a 2003 G35 Sedan with a Bose audio system.
Problem: The parasitic drain on the battery when the ignition is off is 0.53 Amps
I have isolated the problem to the Bose audio unit's backup power line via the 15A [37] fuse in the fusible link block
The car should have a parasitic drain of only 0.07 Amps
Other than the high drain, the Bose system and everything else works as intended.
Im at a loss, anyone have any ideas?
Thank You All,
Sam.
