2003 g coupe wheel upgrade questions
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
dotcombust
Car: g35 coupe silver
Hello - I'm looking at upgrading my 2003 factory 18" rims with a set of 19" Rays g35 coupe factory.
I have the premium package (non-brembo package) so should I have any issues fitting the factory Rays 19s on as is?
How much performance change will I see - such as mpg or 0-60?
Yes I've priced the tires - 19"s are expensive .. but I really like the look of the 19"s vs the 18"s I have.
I've been frequenting these forums for just over a year now so I would just like to to say this is a great resource - thank you in advance!!
-jake
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
Welcome to the club. Glad you joined.
I haven't experience the change from 18s to 19s because mine came with 19s, but the 19s are forged and are the lightest I've been able to find for that diameter.
I know you addressed this already, but 19" tires are horribly expensive. Moreso than 20s in a lot of situations. Just some food for thought.
Since you'll have more rotating mass away from the axle, you may see a slight decrease in performance and fuel efficiency. I don't think it should be drastic.
The 19s should fit the Brembos as I seem to remember them being offered as an option on the 1st gen Gs.
joe603
Car: 2014 Durango R/T
Well get you an answer very soon...
No fitment issues.
You don't have the Brembos, so they'll fit nicely.
GoDaddy
Car: 03 Infiniti G35 Coupe
Whats TPS? I see sometime that some wheels comes with TPS ... does the car has to have something special to integrate the TPS? I got an 03 coupe and also looking for some Rays 19.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Your car already has TPMS (tire pressure monitoring system). They are located at the end of the valve stem inside the wheel. Just re-use your tpms if you get the 19" rays.
GoDaddy
what does the tpms do? you see the pressure somewhere? How do you know mine has tpms already .. i got an 03 coupe .. pretty old...
Astro1
Car: 2003 Infiniti G35 Sports Coupe
No tps on mine either
RED_DET
Vendor
2011 Infiniti G37x
The system is there and you will only know if one of your tires gets below 28psi, then an indicator will show up on your gauge cluster. Look at the valve stems on your car. Are they rubber or metal? If they are metal you will have the tpms. It monitors itself, nothing you see except an "idiot" light on the cluster. 04+ had the system, so I guess you build date would be the key if you have it or not. Just check the valve stems, easy way to tell. Now if you dont have the system, then it doesn't matter if you get wheels without them.
lossimo
Car: 03 6MT coupe 06 Lexus GS300 03 Toyota Sequoia 4x4 Limited 86 Supra MKII
I am very interested in this swap as well.Will there be a fit issue with Brembos?
dotcombust
Everyone, thank you again for all of the replies! And thank you for having me on these forums =)
My apologies for the necro, its been a very busy summer and i'm just now getting a chance to reply.
I do not have the brembos so I'm still looking at the 19"s as an option. Thanks again!
-j
Sentientbydesign
96 I30 - Sold
You should be fine.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
