2003 g 35 coupe trunk won't open
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
wilbanks51
Car: 2003 G 35
i've tried therelease under the dash and my key fob both and neither will open the trunk. anyone had this problem before?
thanks
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Assuming the valet switch in the glove box isn't disabling it, sounds like a bad actuator or bad trunk wiring. Some models like older Maximas have a tendency to break wires in the flex coupling as they age. I don't know if the G35 is one of those, but I wouldn't assume the actuator is bad until you check power and ground to it.
wilbanks51
Car: 2003 G 35
i can't get into the trunk to check wirings. There must be some emergency way to access the trunk.
wilbanks51
Car: 2003 G 35
VStar650CL
Technical Expert
If the back seats don't fold down and there's no key cylinder, you might need to yank the rear seat. There should be an emergency release on the lid once you get in there.
Return to “G35 and G37 Interior, Exterior and Audio”
