My rear lights and turn signals stopped working on the same day last week, including brake lights (I could tell because my turn signal indicators were blinking very quickly).
Since they all stopped working at the same time, I figured it was a fuse issue. I don't have a manual any longer, but the 2 fuse panels I can find are in the battery compartment and on the door (left) side of the driver's foot pedal area.
Neither of these had a fuse that appears to be related to the rear lights (let alone one that needed to be replaced).
2 questions then:
1) Are there other fuse panels located in the car that I should check?2) If not the fuses, what else should I be checking on to identify the cause of the problem?
Thanks in advance for any suggestions -
