ericthered »
https://forums.nicoclub.com/ericthered-u77371.html
Sun Sep 06, 2009 10:51 am
mksue3240sx wrote: >>> There is an updated crank sensor for these. There is probably an open recall on it.
However, there is no MIL light, and I assume the dealer checked memory, too.A crank angle sensor failure would likely set the MIL/show a trouble code, yes?
Like the dealer, I would suspect something that the engine thinks is a normal reason for shutting down, like some security issue. It seems like absurdity to just shut down a car after driving happily for 15 minutes for a security issue, though. The shift lockout works on (attempted) starting.
I was also thinking it may be that the fuel was cut off instead of the ignition. Mostly because I remember pushing the car uphill off the road :-( :-( as well as after numerous starting attempts and did not smell any unburnt fuel, as you might expect. (I expect the dealer should be able to tell us next time they look at it which systems are disabled).
I am also wondering if this is a rare occurrence, or more common. Given the feedback so far, it does not seem common. Once a car instantaneously quits on you while driving a couple times, it leaves a persistent distrust in the back of your mind - these folks need something to restore faith if they are not going to sell it after "fixing" it.
