2003 FX35 instrument cluster replacement
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
OPL1933
Car: 2002 Pathfinder "Chilcoot"
:ohno: I had to replace the instrument cluster with a used one, obtained from a used parts dealer. The replacement unit has a large difference between the actual mileage of the vehicle vs the one shon on the dash. Can anyone advise me on how to change the odometer reading to reflect the actual mileage? What procedures are needed and can I do this myself
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Can you fix the discrepancy yourself, no.
Newer cars store the odometer value in at least 2 modules, cluster and ECM, and in some cases even the BCM. When replacing one of them, a diagnostics routine for handshake is required ("seed and key") to have the replaced module learn data about the car, being the odometer value one of them if applicable. I'd advise taking it to the dealership to see what assistance they offer.
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
