NSR A32 wrote:I understand that what you're stating is based on experience and that's fine. But if you re-read what you wrote, you'll understand what I'm talking about. You made a statement referring to the fact that on every VG33 you have ever seen, you have found that specific A/C hose to be leaking. I was just referring to the simple fact that this was near impossible as you have'nt worked on every single VG33 Nissan has produced so you can't state, in a matter of fact type of way, that they ALWAYS leak.
LOL NSR A32. You are taking this out of context from what I really meant to say. But you are right, nonetheless, as I did come across as, "THAT HOSE IS YOUR PROBLEM." Let me re-phrase my original statement.
Quote »Check your high pressure Compressor to Condensor A/C hose for any leaks. This hose is located on the driver's side of the vehicle, hooks up to the compressor and the condensor. Usually, when we have a VG30/33 equipped vehicle that comes in with a "Warm air blows when A/C is applied," the problem usually tends to be this hose leaking refrigerant. But this may not be your specific case, but it could be.
Also, check your other A/C hoses for leaks as well. If there is a "greasy film" on the hose, especially around the "crimp fittings" where the rubber hoses meet the metal connector, then that can be a possible A/C refrigerant leak. But the best way to be sure would be to take the vehicle into a licensed A/C repair shop or dealership and let them diagnose and fix the problem.[/quote]
