2003 FRONTIER A/C
jimmy 2003
Car: 2003 nissan frontier
MY A/C ON MY 2003 FRONTIER SEEMS TO BE OPERATING PROPERLY.STILL WONT BLOW COLD AIR.FREON DOESNT SEEM TO BE CIRCULATING THROUGH THE SYSTEM.Thanks for the welcome.Should have explained more.Compressor kicks on clutch engages.Freon still doesnt circulate and doesnt blow cold air.No fuses seem to be blown or relays.Freon charge is good.Will not pull in freon on low pressure side.Beats me.
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
it's probably the compressor clutch, but you should have a qualified shop look at it if you aren't familiar with a/c systems.
Welcome to NICO!
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I'd pick up a tester to verify that the system is holding a charge. Might be leaking or otherwise low on refrigerant.
jimmy 2003
Thanks for the welcome.Should have explained more.Compressor kicks on,clutch engages,freon charge is fine.Freon is still not circulating and system is still not cooling.No fuses or relay seem to be blown.Will not pull freon in on low pressure port.Im baffled.Has always worked great.As recent as this past fall.Any suggestions?
