Dachristianman »
https://forums.nicoclub.com/dachristianman-u62413.html
Sat Feb 22, 2014 3:17 pm
I can't imagine that you could screw this job up. After the wheel is off, it's 2 bolts for the brake caliper, and 1 bolt for the hub assembly. There is not a lot to screw up that I can see. Plus, it's about a 20 minute job once you have all the tools out of the tool box. The part is $125 online for a quality part. I found them as cheap as $35, but I spent the extra money for bearings that were made in Japan and a housing sold by an American company.
I also think that it wouldn't be that difficult to put a grease fitting on the dust cover and by pumping some fresh grease in every 50K miles, they should last nearly forever. When I took mine apart, it appears to have failed because the greased turned to a wax-like consistency.
Tom
