2003 Error Codes P1130//P1165//P0507
aaron3313
Car: 2003 Nissan Pathfinder LE
I have a 2003 Pathfinder, with 193K miles. Since picking it up from a private seller, the Check Engine light comes (stays on) and I get the following error CODES, P1130, P1165, P0507. I have replaced NISSAN Swirl Control Valve Control Solenoid Valve, Swirl Control Valve Control Vacuum Switch and the P0507 just started appearing. I have also replaced the entire "vacuum box" with all hoses.
When I press on the gas, it seems like the motor goes into a "2 stage" launch procedure. When traveling up hills/mountains, it rarely down shifts, and when it does, it goes into the "2 stage" launch, sort of like, an on/off switch is being triggered.
Any and all help would greatly be appreciated.
Aaron
Empty V
Car: 2001 Infiniti QX4
1982 Chevy Corvette C3 Shark
What is a "2 stage" launch?
aaron3313
You know the little 4 cyl race cars that mash the pedal, and the engine rev's up, and then seems to stall, rev's up, then stalls, until they driver is ready to launch, my nissan does that.
