2003 crew cab frontier ecm relay location?
djjuddk
Car: 03 frontier
2003 crew cab frontier ecm relay location? I've searched several forums looking for the location of my ipdm & ecm relay. I have found numerous diagrams and pictures of the box & location for a 03 frontier. Thing is none of them match whats going on under my hood. can someone please post a picture or a pathway for me to get this thing out?
thank you
Judd Kennedy
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
The location of the ECM and relay are behind the radio inside the cab.
http://www.nicoclub.com/FSM/frontier/20 ... ier/ec.pdf
Turn to page 669.
djjuddk
Car: 03 frontier
1. so got the relay changed and truck will not start.
2. however now Im getting a p0505 code, where as before I had no codes.
3. now I am taking the Idle speed control solenoid Valve off to detail clean it.
4. what do i next if this doesnot get the vechicle up & running? would i need to get the computr reprogrammed or do you think the ECM itself may be bad if the engine will no turn over after I clean the idle speed control solenoid valve.
thanks for the reply it helped me
judd
Rev_D21
Short answer to your question, I would read that link starting at page 988. The fsm will show you the steps to fix that code.
