Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Wed Dec 06, 2006 6:42 am
What do you define as a major problem? How many miles per year [15 x10 years =150k]. Generally around 8 cents per mile covers maintenance and repairs except for tires and brakes. Many components are designed to last 100k minimum.
AC might be a cost factor if you don't periodically service the compressor oil and change receiver dryers to remove system moisture!
Most sensitive ownwers replace all shocks every 60K [2 sets], suspension rubber isolated components may need replacing at intervals.
$12,000 should cover [$1200 per year prorated [$600 in warranty and $1800 after] plus tires and brakes.
The question is when you hit 150k how much will you leave undone.......most used cars [Nissan brands] in this price range are sold because they get a repair quote for $3,000.
