GHOST 1 »
https://forums.nicoclub.com/ghost-1-u50926.html
Tue Nov 21, 2006 4:58 pm
I have a 03 Altima that was hit in the passenger front-- got into the main fuse and relay box(Nissan Dealership called it a Intellagance Module) it smushed it alittle broke some plugs on the harness,,, i spliced in the plugs and replaced the box,, now the fans comes on and motor won't start---heres the question ,, is splicing the wires changed the resistance to cause code problems,,, or when the box got busted did it mess the engine ECM up,,,
i replaced the ecm with one but it has the same stock number but different part number,,, when i done that the car started but started throwing codes,,,,,
Is it the wiring harness or the ECM?
when doing the self check(on the electrical) the car does everything,,, it turns everything on and off by itself and reads fine,,,
i've built a few but this is rediculous,,, lol
