PhillyKorean »
https://forums.nicoclub.com/phillykorean-u211284.html
Wed Oct 24, 2012 11:17 am
Hey guys I have a 2003 Nissan Altima 2.5L 4 cylinder engine. last week the Service Engine Soon (SES) light turned on again. I went to autozone to get the codes read and I got 2 codes that it picked up. one is: P0725- Engine Speed Signal Circuit and the 2nd one: P0335- Crankshaft Position Sensor (CKP or POS) Circuit Also car sometimes has a hard time starting or turning over especially when the weather is cooler. You have to crank it about 2-3 times for it to start What would cause both issues to occur at the same time? I just had cylinder work done (the mechanic replaced the faulty cylinder), spark plugs changed, 2 ignition coils replaced, valve cover gasket sealed with silicon, New battery(585 CCA), new rear drum brakes on both sides, inspection done, emissions done and passed.
I think it might be a recall item because of the failed crankshaft position center but not sure, and if it is, Can Nissan say that I am too late to qualify for the recall. The car was bought in 2003 I believe like March, didn't have any issues with it until now.
