92FLQ »
https://forums.nicoclub.com/92flq-u58318.html
Sat Sep 12, 2009 5:35 pm
PROBLEM SOLVED:
After a session at the dealer, and another at a very good independent local shop, where the transmission and TCU and ECU were all checked out, nothing was found, and neither the dealer nor the independent shop were able to cause the "neutral" event to happen even though between the two they had the car for a week and 2 days.
Of course another "neutral" event happened while driving in-town two days after we gave up and I got the car back, with the same results; and then three days later, the "neutral" event happened again at highway speed (65 mph, no cruise).
After coasting to a stop as before, THIS time for some reason I decided to turn off the ignition switch ( when this happened before I had always left the ignition alone, as the engine was always still running, and after a few minutes was able to shift into drive again and go on... )
SO this time when I turned off the ignition, after a few minutes upon trying to restart the car I had a no-start situation with the typical "click-click-click-click" of a dead battery. After some very fortunate good-samaritanism ( if you are ever in Southwest Florida and need a tow, call "A Budget Towing 239-896-5008, the owner of the company pulled my car back home for free ) the next day I pulled the alternator which failed a charge-test.
Replaced alternator (which is a pretty involved job, had to remove radiator to get it in-and-out) and it has been four weeks now and no problems, no other "neutral" events.
After discussion with both dealer tech and independent mechanic, we all seem to agree that the transmission must have been going into some kind of fail-safe mode as it either lost electrical power intermittently or experienced a low-voltage situation, due to the ailing alternator.
I have had alternators go bad on other cars before, but this was a first for the symptoms being manifested in the transmission before anything else is apparent; there never was any dimming of headlights, loss of radio presets, "battery" CEL, or anything else to indicate a low-charge rate situation. Maybe these transmissions are really sensitive to voltage or amp drop or fluctuation...
I hope this maybe helps someone else with weird symptoms in the trans or elsewhere; sometimes the problem is not where it seems!
