2003 Altima 3.5 oil leak Help!!!!
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
sr_240sx
Car: 1989 240sx w/SR20DET and 2003 Altima SE 3.5L
It seems to come from the left side of the oil filter but at the same time does not look to come from the filter it self someone told me it could be the oil cooler but I cant find it. Anyone had this issue before? Any pics. on this or a How to fix this? Like a step by step thing!!!All the help would be great. Thanks in advance!!!!
98blackbell
Car: 1995 Nissan 240SX SR20DET(STOLEN)
1993 Nissan 300ZX 2+2
2006 G35 Coupe
1998 Chevy Tahoe 2DR 5.7
1975 Datsun 260Z Turbo
Don't know if you fixed this, I had the same thing. Had to replace the whole oil filter adapter and new gasket. About 180$ in parts and a good 2 hr job. Shop wanted 450.00$ Was a mess. Kept losing oil couldnt figure out thought it was valve cover gaskets then oil pressure switch.
sr_240sx
My problem was the oil cooler o-ring but the oil problem is consumtion about 2 qtz. every oil change.
98blackbell
2006 G35 Coupe
Yes consumption is a problem. 130K on the motor about a 1/2 qt every 3 tanks fuel. When you have a leak and consumption you gotta watch it!
Return to “3rd Generation Altima Sedan (2002-2006)”
