RICERMAN wrote:Im waiting to hear how that sensor works. Does it know where the crank is by using a crystal ball or telepathic transmission? I think maybe a do-hickey mounted on the flywheel might work along with this sensor but I was told thats not so........Any car that has the OBD11 system works the same as others,,,,,wheather it be a ford a chevy or a KIA.thats how ford got mentioned,,,,,,,,,didnt you know this? It became a law back in 1996
The only law that became effective in '96 was the diagnostics portion of the OBDII emissions system. All other facets of the manufacturers are still their own. If the O2 sensor has a failure, then a code for the O2 sensor will come up under the generic scan tool reading. But a manufacturer can still have a specific code for a specific failure of the O2 sensor if it so desires. As long as it still has the generic code available for the generic scan.
Nissan does not have a sensor actuator. Period. There is no discussion on the matter, as it doesn't exist.
The crank has a sensor wheel on it, at the back, inside the block. To change the wheel, you would have to replace the crank.
As far as the sensor goes, I have never, ever replaced it from anywhere but under the vehicle. I have a 90 degree screwdriver that I use as a prybar for the green lock. I push against the axle for leverage and then the lock goes down. Then I use an extension with a 10mm wobble with my 1/4" drive ratchet and remove the sensor. I usually have to use a pair of needle-nosed vice grips to remove the sensor, but since it's bad, and the directions in the recall say it has to be destroyed anyways, it's a non-issue.
I've been working on Nissans for a long time. There is always a trick.
