APEXi240 wrote:Actually it was your fault because you were following her to close...that was the cause of the accident. You ever heard of the two second rule??
If you rear end someone...it is always your fault. The only way I can see that it wouldn't be if the person in front of you had no brakelights...so his comment was pretty acurate.
