atomicdog3000 »
https://forums.nicoclub.com/atomicdog3000-u57376.html
Sun Feb 18, 2007 5:56 pm
Ok... so here are the results of the coil test (taking the connector to the coil off while the engine is running to see if it has a negative effect)
Cylinder 1,3,5 (passenger side) = each time I disconnected the wires it had a definite negative effect. As soon as I reconnected them it was better. So they all seem to be working properly.
Cylinder 2 - I had to skip this one in the interest of time... it is buried underneath a bracket that has a connector or some kind of a sensor or solenoid on top of it.
Cylinder 4 - disconnecting this had almost no effect (interestingly though, when I had it disconnected and tried to turn off the car and turn it back on it was much harder to start) - possibly bad
Cylinder 6 - no effect - possibly bad.
So, just to try something, I put a voltmeter on the connectors... one on a good cylinder (3) and one on an apparently bad cylinder (4). On both, I got the same readings - 14.8 volts constant on the white wire with stripe, 150 - 210 mV on the other colored wire, and nothing on the black wire (I'm assuming this is the ground). Unfortunately I wasn't using a good voltmeter so I couldn't record the fluctuations on the second colored wire. It was definitely fluctuating, but too quickly to record with the naked eye on a crappy voltmeter. But just based on what I observed, the good cylinder and the possibly bad cylinder seemed to be receiving the same input from the ECU, but there is no way to really tell.
So, I'm still wondering if those coils are bad, or if they are just firing at the wrong time because of something related the other OBDII error, the Intake Valve Timing Control p0200. Tomorrow I'm going to check the cost of those 2 coils (and the associated plugs, I might as well)... but I'm definitely still looking for ideas if anyone has any. It's a place to start I guess.
It's weird to me that 2 coils would go bad at exactly the same time, and WTF coils shouldn't be going bad with only 36000 miles on the car.
