djwarner wrote:Not to state the obvious, but every time I've had that problem, it's been the battery. Other possibilities are corroded battery cables, a bad regulator, or weak alternators.
A trip to the Auto parts store to test the battery under load is the next logical step.
I would definitely agree. Get the battery tested, and if it is OK, the starter is your culprit. I found that if you unbolt the motor mount and jack the motor up a couple inches, along with adding lots of profanity (
), it allows easier access, but that's on a 94. If I had it to do over again, I'd pay someone else.
